Suspension help
HOE_RUNNER
Need help figuring out what lift kit to go with!!
All I want to achieve is a level 3in lift, can anyone point me in the right direction?
Also not want to spend thousands of dollars on a high need off toad suspension, this would be mainly ascetics and some off roading.
Thank In Advance
As [MENTION=139682]Simpleman74[/MENTION] stated look in here...
http://www.toyota-4runner.org/5th-gen-t4rs/165065-5th-gen-4runner-lift-buyers-guide.html
The sticky he was referring to is the sticky at the top of the 5th gen homepage titled "Modifications, Write-ups, Quick-Links and FAQ's".
Once you narrow down more what you are looking for type it in the search field with "5th gen" in front. There are numerous threads on every type of lift conceiveable on this forum already. Then look at the lifted pics section or in those threads and you can post specific questions on the lift you are looking for, or even pm people with the setup you are looking at. Most on here are quite helpful (especially if you show effort by going through the research process a little bit first)
Good luck!
fhgy0045
