Suspension option to reduce swaying on turns?
I did some work on my suspension last year that has it handling much flatter. I have the standard yellow shock OME 3” kit. The shock/spring combo adds about 3” front and 2” ish rear lift. First I swapped to sway bushings front and rear to urethane. This did result in a noticeable change on its own.
I had also installed adjustable rear sway bar links. Mine are Dobinsons, although several sources are available. The purpose here is to correct the geometry of the rear sway bar after lifting. Two reasons. Number one is to lower the ends of the sway bar so that it is as near parallel to the ground as possible. This puts it back in position to function as designed to combat rear sway. Second reason, after lifting, unless you have extended sway links to lower the ends, the travel of the sway bar is limited. So, in offroad situations, the axle droop can be limited by the sway bar’s travel. Adding the adjustable links fixes this and allows for the droop to be limited by the max extended length of the shock. Good stuff, eh?
Lastly, the panhard bar. Factory panhard geometry puts it pretty much parallel to rear axle. Lifting the suspension will change the angle on the bar. The bars function is to keep the rear axle centered under the truck and also to brace against side to side motion of the axle. It cant do either very well unless it is parallel to the axle. An adjustable panhard bar can be used to re center the rear axle under the truck, but does nothing to help with the bracing against side to side motion. A panhard correction bracket fixes both issues without replacing the bar itself. Forum member eimkeith sells these. It is a weld on bracket, but it retains factory mount positon in case you ever go back to stock ride height. After installing it extends the length of the axle bracket to get the bar parallel.
These three mods together made a great bit of improvement to handling. Its about as near to slot car handling as one can expect from a lifted vehicle.
Lastly, is this a new thing for her? I had a vertigo episode awhile back that really messed me up for about 6 months. Maybe theres medical help for her situation.
Also, my ex got car sick..unless she was driving. Let the girl wheel!
Thanks for the info! I have bilstein 5100's and 2" OME springs front and rear. I think that I am going to try and crank the fronts up a notch to get closer to 3" and also add some preload to stiffen things up. I also got the sway bushings in and will get those installed. I have had the PCK kit but just have not got it welded in yet. My friend will do it for me, but the weather has been on and off so hopefully will get it done soon. Hopefully that combo will help.
The motion sickness is definitely not anything new. we rented a canoe on the lake one day and that made her sick, and its just something about riding in certain cars.
I installed the front and rear whiteline poly sway bushings. Havent installed the rear endlink poly bushings yet, and no driving yet. will update with my experience.
Upon install I can feel a significant difference in the poly vs oem rubber compound though. And mine should be "almost new". my 2018 only has 14k miles since i got it new. We will see how significantly it improves handling.
to add this has been mentioned before, here is a post with pictures
https://www.toyota-4runner.org/3208305-post19.html
it's best to read the complete thread, it would be wise to coat the link to prevent rust.
Thanks! I may actually go and buy those longer links now. I went out and bought some flex head ratcheting wrenches and changes out the rear link bushings in about 20 min.
I drove this morning and the sway bar bushings did make a noticeable difference on turns. I would recommend it. This is how it should have felt from the factory.
Awesome! I'm glad they worked out, I also recommend Whiteline sway bar bushings as well for cheap buck mods that pays off.
Do you have a link? Didn't see them on the whiteline website.
I got them on ebay but part#s are
W23432 front and W21053G rear.
The front for sure is an exact match. I think the rear sway is 19mm but the OEM bushings were labeled "20". the whitelines said 19mm. They fit fine though.
Crookedcat
