Suspension parts maintenance
Rushingman
Is there any maintenance i need to be doing on my aftermarket suspension parts? i.e. coilovers, springs, UCA (total chaos)
Something in my front suspension components are very very squeaky, I'm thinking its my front coils. Any recommendations for fixing that?
2007 4runner limited 4wd v8
toytec boss suspension lift
toytec 1" body lift
total chaos upper control arms
35x12.50x17
Don't know if that's needed, but there it is anyway!
Probably you UCA uniballs. Spray generously with tri-flow, it should go away pretty quickly if that is the problem.
toytec 1" body lift
35x12.50x17
My guess would be that the UCA's poly bushings need to be greased.
Energy Suspension 9.11104 8 Oz Tub Of Lubricant https://www.amazon.com/dp/B000MW5SJ4/ref=cm_sw_r_cp_api_igVuyb0YDPG50
I'll second this. If poly bushings dry out, they can get VERY noisy.
I like redline sticky synthetic grease.
Your coilovers will need to be rebuilt at some point. Thats why we spend the extra coin on them- se we can rebuild instead of replace like the cheapo bilsteins. Most MFG's recommend every 6months, but that would only be realistic if we used these like they are meant. As a daily driver and light offroad vehicle, your front coilovers should last 5 years before you blow a seal and oil starts leaking. but that would not likely result in noise, just destroying the internals.
My UCA bushings are loud right now as well. Typically it seems to happen when it gets cold, kinda goes away once warm. I could probably throw some grease on mine as well. Just getting that round-to-it is the prob!
Do i just apply the lubricant on flat ground, with out any flex?
Or should i try it on flat ground, and with some flex in there?
you will need to lift the front off the ground, remove the UCA off the frame, remove the bushings, clean and grease them, replace.
unless you have zerks on your UCA bushings.
if your just talking about the uniball or joint at the spindle, just spray it down. Wont make much difference how you apply it and it will not last long
