Suspension Squeak
amnt
I have the Toytec Boss lift on my 14 T4R and have been noticing that when the suspension articulates at slow speeds I get a lot of squeaking. This is happening around town and not on rough terrain.
Has anyone else experienced this issue? Any suggestions on what it might be or how to get rid of it?
Mike
:noidea:
Sounds like something isn't packed with grease that needs to be. Also, get some dry graphite lube and hit all of the links. That should solve it.
Mike
:noidea:
It's crazy you say that I heard mine squeaking today and I know I greased everything that needed to be
suspension squeak
Thanks, I will make sure all is greased well and I will get some dry lube as well. It sounds similar to a spring squeak I used to have on my 68 mustang.
thanks for the help.
I have the same issue, you can hear it very well at slow speeds, especially say in a parking garage, over any little bump. Definitely sounds like it's coming from the rear on mine. I can replicate it by pushing up and down on the hitch ball on the rear. Haven't had time to investigate further, wonder if yours is the same noise?
alexaturner
