Sway Bar Links - Eugene, OR
Do you still have those adjustable end links for sale? If so, how can I purchase?
I'll shoot you a PM shortly.
quick heads up, that isnt the same as a 3rd gen 4runner. the pickup points are different.
once im done with my travel at the end of the month i really need to pick a set of these up.
Yes, I'm aware 3rd Gen's are different. What you quoted was about the 4th & 5th Gen disco's, and those are exactly the same as FJ's.
Mike
Few sets of links going out today.
Why size is the shortest length bolt in the 5th gen standard kit? I had a similar issue as someone earlier is the thread with the bolts being a little short. I used the shortest of the three lengths in the rear and the bolt ends inside of the nylok. No big deal just want to pick of two slightly longer bolts. Thanks in advanced.
If you get a 7/16-14 x 2-1/2" you'll be in good shape.
Mike
Mike
Just noticed in the pictures above there is an additional aluminum washer? On two of the bolts. My set didn’t have this, is it possible I’m missing something? Also, after tightening everything up, the rod end bearing boots just pop over the head of the bolt, had any word about this from others? Thanks again for your prompt response.
The spacers are new addition, and isn't something that I would worry about just yet. If you have a popping sound from the front with your steering wheel at full lock, let me know. The spacer will eliminate that. There's nothing to be concerned about with the boot either. Some people have used a small zip tie to hold it in place better.
Mike
Mike,
Can you let me know what size quick release pin is used for the front disco for the 5th gen? Mine are bent or stuck or have the ring pulled out. I need to replace one of mine. The bolt sometimes rotates and allows the pin to interfere with the stock sway.
Thanks,
Will
Mike,
Thanks,
Will
3/16" diameter
Mike
Mike
Pm sent regarding this. Thanks.
I have an update on lead times. All standard links will ship within 24 hours. We currently have stock on all 4runner models, FJ Cruisers, GX's, and Tacoma's.
Mike
So are anyone else’s front links loud? I hear popping from both sides over minor bumps and during any turning/weight transfer.
You shouldn't have a popping sound if you installed the spacers I sent you. The popping sound was the link popping off the spindle as it cleared it. Send me a PM, and I'll do my best to help you out.
Mike
