Switch panel locations
What is the best auxiliary light switcher for the T4R?
  • Total voters
    24
Just purchased an Auxbeam 8 gang. Mine came with add a fuse with a 5 amp fuse in it. Is it ok for me to replace the 5 amp fuse and put a 10 amp fuse? I've read some guys putting the add a fuse in the acc slot. Any of you guys know where that would be? I have looked up and down my 2022 4 runner fuse box diagram and can't seem to find it. below is a diagram of a 2022 4runner fuse box. Please dont mind the ac writing on the pic.
i run the trigger 6 shooter. I have no complaints. Its very easy to add lighting accessories.
Not Toyota specific, but it’s generally not a good idea to use a higher amp fuse in any location. You want it low enough to blow before damage is done elsewhere.
While I don’t have experience with the Auxbeam 8, the switch panel should only require minimal amps anyway, as it only handles the switching/triggering. The relay or main unit handles the power distribution duties.
AndiGarage
