NC[4]Runner
So I've been working on a vertical mounting solution for the Switch Pro 9100 and wanted to get some feedback, thoughts, concerns, comments and other input from the community.
This is one version of the Mount Tray by DC Distribution (there are a few versions in the design phase). It is installed on a 2014 Trail Edition (with KDSS, if that matters) See the photo. Note, of course, that the SP9100 is not fully installed as the wires are not there.
It has installed on it a Blue Sea BusBar and Blue Sea terminal block for connection leads to and from the SP9100 and mods that you are connecting to it. It is made from 5052 Aluminum and weighs, as you see it here, just over 2 lbs, with mounting hardware.
I'm already hoping for a version that can accommodate a fuse block and a circuit breaker, but I'm not sure yet. Some topics I'm needing input on are things like:
What else would you want to mount?
From a consumer standpoint, what option would you want available?
Would you want a full package kind of thing? Including the bus and terminal bars with mounting hardware (SP9100 excluded of course), or would you rather go find it yourself?
Would a blank mounting surface be something of interest so you can drill holes yourself ?
Let me know your thoughts.
