T4R went into “Limp Mode”
hahaha! I have a 2021 TRD ORP also and I'm wondering if anyone who is experiencing the limp mode issue are from this years models only.
I just got the rest of the C4 low pro bumper in and it's currently getting powder coated. I'm gonna go down to the local shop to order a Baja lightbar to go with the bumper, they got a Labor Day sale going. But I just don't wanna run into that issue. I guess it pays to play.
2 years ago I bought my 2016 with a CPO warranty and had the limp mode issue the day I drove it home from the dealer. I got it fixed under warranty right away and it's been great since. I've added quite a few LEDs to the rig since then, too. From what I've read, it seems like this issue can happen to most model years of the 5th gen.
If I remember correctly, on Toyota's website to build a 4runner, wasn't there an option to pick upgraded LED interior lights?
Glad to see you finally got this squared away. Now are you going to start reinstalling all your LED's. What a hassle.
I asked and or discussed the following with them. Since the problem occurred without any LED's in the vehicle, did they see any viable reason that would prohibit me from installing my LED's?
They stated if an issue occurred they would have to look again to see if it would be covered under warranty due to LED's installed. Which I think is a bunch of BS!
Going to install them a couple at a time...methinks! :clap2:
I hope it stays fixed for you. I can’t leave anything stock, but every time I change something I’m waiting on the electronics to not like it.
Please research that and if you find it, please take a screenshot & post it or link it!
So I talked to the parts guy at my local Toyota dealership. He confirmed that it was an option on the 2021 to upgrade the interior lights to LED. But it was something that had to be done during production and not at port.
That’s strange, I’ve looked thru all of the build sequences and never saw that option.
I’ve also asked my parts contact if there were any Toyota replacement LEDs, I was informed there were none.
I would love to get part numbers if that is an option that you could ever get from your contact.
Thx
Thx
Yea I know that option was not there when I first did the online build last year when the 2021 models started to come out. But I saw it earlier this year as an option. Parts guy even looked it up and showed on his computer that it was something he couldn't order.
So,
Here is the invoice from today!
pomy3GGZj
I’m glad you finally got this fixed. Too bad it took so long for it to reoccur for Toyota to acknowledge it and apply their fix for a known problem.
You are not alone, this has been an occasional issue with the throttle body that has nothing to do with interior LEDs. Here’s one case, see post 7 regarding the text for T-SB-0092-11 August 9, 2011.
Repeated P2111 Code
Today, I finally got Toyota Corporate for admit and confirm that my LEDs did not have anything to do with the failure code P2111 for the throttle body.
What an ordeal to go thru to get Toyota to repair an item on a new truck where there are known issues and try to blame it on the end user until the end user proves otherwise.
#Toyota Corporate ought to take note when these things happen and try to do just the opposite!
So, I will re-install my LEDs and see what happens next!
Thanks to all that pointed out TSBs on this issue!!!
OP, glad to see you got it sorted.
I will add a similar experience with my sprint booster during an off-road trip. Going hard through deep sand I got into limp mode under the same code p2111... in the sand, limp mode would get you nowhere but stuck.
Luckily I had the OBD reader and torque app on hand. After a few attempts, I eventually removed the sprint booster and cleared the code. I hit limp mode two or three times that day (after removing the sprint booster), but it finally went away after that. Guess it must've taken some time to 're-learn' things.
Now 4 years and 45,000 miles later, no sign of p2111 anymore. Knock on wood.
Did you ever re install your SB?
Has the same issue with my 2013 SR5 a few weeks ago. Had throttle actuator code on my obd scanner app and took a gamble on it being the Throttle Body. Seeing as the TPS could not be ordered separately, it was a gamble. Got a new one and replaced it and code is gone and car is running fine.
Intermittent problems can be a bear to solve. But sometimes the simplest diagnosis is correct. A mechanically sticky throttle valve is just that, due to contamination or a manufacturing flaw. The solution is to clean it or replace the whole assembly.
Here’s another document for your reference library:
https://www.purefjcruiser.com/docs/... Engine Control System/SFI System/0050050.pdf
I wouldn’t hesitate to install all your interior LEDs. And the SB. However, I would not install any aftermarket headlight LEDs, for different reasons.
I'm surprised you got that kind of run-around from Price LeBlanc. Tho I suppose the old man has been dead for at least 10 years now. I can still hear him saying "Dahlin!" in those commercials.
Thanks [MENTION=200736]ElectroBoy[/MENTION] !
I have indeed re-installed all of my interior LEDs, my grill marker lights, my MESO puddle lights, my reverse LEDs, and Rigid backup LEDs.
Installed my High beam LEDs as well. Just received today a replacement BTF-LIGHTING FOB LED Strip for my under the hood light.
EDIT: Installed my Under The Hood Light
I concur that it was a failure of the OEM TB that came on the engine from the factory and nothing to do with any LEDs.
I haven’t received my SB back from the factory yet as the we’re going to inspect it for possible cause of the issue internally.
I have been dealing with them since …. well for a long time.
I think honesty that Toyota has tied there hands because of a couple known noise issues that feedback to the computer from cheap electronic equipment installed. These newer vehicles appear to have become very sensitive and therefore…. Toyota questions anything aftermarket.
So, I think PL Toyota is kinda caught in the middle.
I know Eric, Todd, Richard and PK as well as people on the sales & finance side.
I have no issues with them personally, but I question the heck out of them, especially on this last deal!
I told them from the start that my installed LEDs had ZERO to do with this failure.
They were directed by Toyota Corporate.
Another part to this is I have been in contact with Toyota Corp and finally got them to agree/admit that is was a faulty throttle body that caused the issue, since my LEDs were not in the vehicle upon last incident!
