Techstream Cable Question
I did buy it before Christmas...but have yet to use it.
I do believe [MENTION=29376]sandcrawler[/MENTION] has figured it though..
i don't think it was that exact cable, but i understand most of them to be more or less the same Chinese knock-offs.
this post was particularly helpful, most specifically the link provided to the PDF instructions and TISKEY software on this site.
i followed those directions and had no problems getting past the software registration business but couldn't get the cable driver (.msi file) to work for the life of me. derp. the driver provided on the CD that came with the cable worked perfectly. :nerd:
i did all this on an old, non-networked XP laptop, btw.
good luck!
good luck!
Are you able to update the techstream software to the latest version after you install it? I have a 2015 and it looks like i need version 9.31.000 to be supported.
i'm not sure. if it were me, i'd try to locate a download of the specific version you need before doing anything.
Thanks. Think ill order it and give it a go.
Yo, if you get it to work maybe I can swing by and get my seatbelt chime turned off? I've tried with the cable I have and no dice on my MacBook with VMware or Bootcamp.
For sure. Ill let u know when i get it up and running..
You are correct, for 2015 you need 9.xx.xxx version.
I have 8.30 installed on an old Win XP laptop and shows only to the 2014 model year.
fyi:
my techstream was bought in 2013. last friday i had a 2015 toyota corolla in to program a extra key to it. It pulled up as a 14 and i was able to program it fine. i am not 100% sure but if anyone is local in philly and want me to try it on their 2015 with my tech stream. PM me
<a href="https://www.flickr.com/photos/129154214@N04/16293806395" title="20150116_102435 by gshadow3225 .., on Flickr"><img src="https://farm8.staticflickr.com/7515/16293806395_6689321094_z.jpg" width="360" height="640" alt="20150116_102435"></a>
<a href="https://www.flickr.com/photos/129154214@N04/16106264978" title="20150116_102408 by gshadow3225 .., on Flickr"><img src="https://farm8.staticflickr.com/7463/16106264978_d418bbd28d_z.jpg" width="360" height="640" alt="20150116_102408"></a>
in that case [MENTION=14008]Greedy[/MENTION], sounds like you can use the 9.10.037 software that is available to download via a click-through in the first link i provided below...
Thanks [MENTION=29376]sandcrawler[/MENTION]! I looked up the recent updates for Techstream - and it says that the 9.30.00 update added the 2015 4Runner, so I think that is the one that I need.
