4Reak Show
Okay guys, these are the codes that it's throwing:
C1201 - Engine Communication Circuit
C1223 - (ABS control system Malfunction) Replacing with a new brake switch
C1249 - (Stop Lamp Switch Circuit) Replacing with a new brake switch
P0171 - Bank 1 System Too Lean
P0325 -Knock Sensor 1 Circuit (Bank 1)
P0330 - Knock Sensor 2 Circuit (Bank 2)
Should I start with replacing the knock sensors?
Wires are likely disconnected from knock sensors. Both to go out at the same time you had the SC installed is too coincidental. Look right behind the timing cover plastic on the top front of engine. I think that's where the connector is for them.
P0171 is most likely an intake leak. My guess is the supercharger mounting bolt in back isn't fully tightened. Or a hose is off.
