Speedy
Member
Thanks, this is super helpful to compare to! I haven't tracked timing in a third gear pull for a while, I wonder if that's the difference? Only one place I can safely go that fast. Your second gear timing is pretty close to what I'm seeing, you have a few more degrees though. I actually don't really care what timing I run in a third gear pull, since Ill never see it lol! I also run about half the methanol that you do, my nozzle is approximately 3.5 gph, that is if our pumps are the same PSI.
I have a few more tricks I'm going to try. If it's my fuel, I'm trying Boostane, which has some nice dyno runs showing it increased power by advancing timing. Not expensive either.
If that doesn't work, I'll try MAF tuning into tricking the engine the load is less. Maybe even fiddle with the IAT... not sure how our ECU's work though.
If that doesn't work I'll try a step colder plugs. I asked the facebook group and several run IK24's, especially if they run the 2.1" pulley.
If by all that my timing hasn't budged then I'll live with it!
First thing I'd do is get a bigger meth nozzle. The one I started out with wasn't anywhere near up to the task. Ideally you want the AFR to drop about 1 point when the meth kicks in, so my AFR is tuned for 12.5 0 13 and with the meth it's 11.5 - 12.0. It's been a while but I think I went over that in the video on the meth kit install.
