The 4th Gens rear hatch latch what a poor deaign.
It's been the subject for many years that the 4th Gens rear hatch latch, along with the whole design of the rear hatch, was an item designed to failure.
First those relaching motors how many have had them fail? And the cover under the latch that the nasty black stuff comes out all over ones fingers when the sealant gets hot.
Now today with the Temp. at 16 degrees F the cover becomes so stiff, one can't grip it tight enough to get the hatch to open.
And another item there is no way to unlatch the hatch from inside the truck, even if you get into the back of your truck there is no manual handle to allow one to open the hatch.
What a really poor design Toyota.
Anyone else in very cold weather notice this item?
The hatch on my 2008 4Runner is the one item i really hate, and even with all the things i do like about my 2008 $Runner it just might be the reason i sell it.:repuke::repuke::crybaby:
oddly enough I have a 08' and with 150k on it....haven't really had any issues with the liftgate at all. I actually like that there are motors that pull it close. I think the 4runner is the only that has this. Motors will and do fail seals with fail with time. If the latch is stiff in the cold, replace it. it is a 12years old after all, things will wear out and break down.
The latch is not stiff it's the cover on the underside of the latch that is stiff in 16 degree Temp., when you put your fingers under the latch don't you feel this cover it covers the release button.
I am guessing you have not had the black goo on the underside of the latch cover leach out from under the cover and get on your fingers.
If so your one of the lucky ones.
I’ve also never had an issue with my rear hatch latch. I’m one of the lucky ones!
I did have to replace my rear wiper motor.
Seems this has been around the block a few times......
Rear Liftgate rubber button replacement?
Yes it has and it's a shame Toyota has done nothing to get it fixed and fixed for the many people who have trusted Toyota, and now find they are just on their own to pick spending $350 Plus the labor at their Toyota dealers service Dept. or do as many have done glued something to the underside of their latch's.
I understand it's not a major safety issue, but it's enough for me to not again buy a Toyota product.
Things wear and break down :confused: Seems silly to write off a brand because rubber doesn’t hold up to the elements for over a decade. It’s a $30 part.
TOYOTA GENUINE 4RUNNER BACK DOOR OPENER SWITCH ASSEMBLY OEM 84840-35010
Well it was 16 F today i had a ton of food stuff in the parking lot of my local Walmart, after fighting people through the store, as a BIG ice and snow storm on the way, then i am standing behing my "trusty" 4Runner, trying and trying to get the hatch open had to just jam everything into the backseat.
Many people were loading their autos and trucks, and looking this fool trying to open his rear hatch having to give up and jam everything into the back seat.
You bet i felt let down and really POed with Toyota poor design.:redbrick:
I had issue with '08 rear latch over 4 years ago, only in sub freezing temps.
Simply soaked latch down with WD40, no problems since.
i had to replace the rubber button cover 2 year ago. I hear excessive summer heat can ruin this button cover. Got replacement off Amazon for $12 and even came with small angled screw driver needed.
Used my rear hatch this morning cold when 9 degrees... no problems.
Hope this helps.
Must be Toyota’s rear hatch scam :crazy:
Hope this helps.
Thanks.
Why didn't you just roll down the back window? :hurt:
Well, you know, cause; Toyota exploding rear window syndrome. :fish:
I just replaced my rear hatch switch and cover. On a 14 y\o vehicle things wear out. Big f-ing wah....
Only valid troll observation, would have been nice if Toyota had put release button in the glove box. But then neither the troll or I would find it because I'd wager both out glove box lights are out.
Wah /s
my 08 had a similar problem and if it wasn't closed properly in the winter the trunk would open when i hit the first bump on my driveway. A good cleaning and spray with CRC knock'er loose solved that.
Wah /s
haha.
Also OP, reach out to t4r.org member here [MENTION=165350]nytosc[/MENTION] and ask him about the camping mod kit that he sells. That will fix you not having a button to open from inside the hatch. I can lock/unlock, roll down/up window and open hatch all from inside and without the key in ignition. Perfect for camping in your vehicle. I also have it on a key fob that he set me up with.
H.Sikina
