The Dark Knight from Kazakhstan Build Thread
New photos.
And some vid:
This Headlights are STOCK. Just tuned. Please purchase that "angels" (Predator Orion V2 form Lightwurkz) and then I will explain how to do it. :thanks:
Ilyas23, I have bought the Orion predator rings from Lightwurkz on ebay. I have noticed a problem, the four identical size rings do not align to the headlights. The rings for projector hole are too big and does not fit evenly (one side has more room) The rings for the high beam hole are too small because the highbeam bulb hole is too large and fits right on through. Did they deliver me the wrong rings? Also, are your rings a full circle or are they U shaped rings?
They are small than the circle on the headlights. We fit deep into high beam. Look at the photos, and do how we did, I couldn't explain more:
There are small than the circle on the headlights. We fit deep into high beam. Look at the photos, and do how we did, I couldn't explain more
Thanks for the photo! So, the rings for the projector hole do not line up perfectly correct? When I try to place the rings for the projector headlight hole, the rings are not perfectly fit because of the bump from the high beam side. And when I place the rings on the high beam hole, the rings are smaller than the hole so there really is no "fit" except to lean it on one side.
You should make a podium in the high beam side and glue the rings.
I can not believe how awesome your 4Runner is!! I was trying to brainstorm some ideas for making mine stand out a bit more after i install the rest of my exhaust components but damn your Runner inspires! In all my years with Toyota I have never seen a Runner like that. Very nice ride bro!
Thank you very much! It is very pleasure for me to hear this respect!
Is there a special way you put them in? I do not think glue its self will stay in place. What did you use as a podium?
I'm thinking of drilling two holes, one on the side and other on bottom and then just zip tie them so that they stay securely on.
I think you should find in your neck of the woods the place where working with headlights, plastics etc. and find the way to fit the rings.
H.Sikina
