The Inverter Switch, T4R 5th Gen
Farzad_K
Member
So, the inverter has two settings, one that requires the car to be driving (400W), and the other that requires the engine to be running but the transmission can be in parked position (100W).
I had an occasion when I needed to be charging a pair of batteries using the inverter, and nearly every time I restarted the engine after having made a stop somewhere I forgot to push that switch on. I wonder if there is a reason Toyota did not design the inverter port to be powered when the engine starts, and automatically switch to higher power delivery when the transmission is put in Drive.
Is there an after market switch that can manage this more intelligently, such as powering it by default when the engine starts and letting the driver choose the high power when possible?
If you have modded yours, what did you design?
seltzernator
