the JACK is JOKE.
Or you can listen to what everyone is saying and learn how to use the jack properly.
when tire was completly on the rim i couldn't put the jack any where else excpet the Axel or the fram.
but I see that your tring to help in your owen way. Thanks
Maybe you should learn how to read all the posts before putting someone down. THIS IS A COMMON PROBLEM WITH SEVERAL TOYOTA TRUCKS!
Koz
Koz
Koz, are you trying to say that Toyota gave us jacks that don't extend far enough to lift our vehicle's tires off the ground enough to change a flat tire? That sounds crazy to me. My bottle jack extends far enough to lift my tires way off the ground. Now if your 4Runner is straddling a ditch or something, you might have a problem, but never on flat level ground.
And besides, if you put the jack under the lower control arms, you'll lift the wheel/tire without allowing the suspension to droop. I guess you can say it's just a matter of knowing where to put the jack to be the most effective.
So you never told us....is the bottle jack broken? Does it extend all the way up? If not, just go buy another one to replace it.
You shouldn't have this problem if the jack is working properly.
Only time I had an issue with a Toyota jack is when I was running a truck with a 33 12.5R15 tire. It was juuuuuust long enough, but if the road was uneven, I'd have to find another spot.
Many people are used to jacking the car up by the pinch seam front of the rear wheels. I believe Toyota is meant for the axle tube closest to the tire as you could get. That is where I always went. Front was either the tube (solid axle) or the lower control arm.
Exactly, I had a flat on my 98 Taco PreRunner and the OEM jack would not lift the vehicle high enough to put the spare on. It had the TRD off-road package (31" tires). Over the years I read many posts of people complaining about having problems with the stock jack.
Koz
Koz
Wow, that's ridiculous. Did you try putting the jack under a control arm to avoid having to deal with the suspension droop?
Either way, I'm glad the 4Runner bottle jack is long enough to avoid that kind of situation!
Koz
Because you say so? Comparing a stock jack on a 10+ year old vehicle to ours is hardly applicable.
It's most likely just user error, no biggie. Nothing to get so worked up over. I wasn't putting anyone down.
OP, like I was saying, just try listening to everyone in this thread, and test it out in your driveway before you go waste money on a new jack.
not sure if the runner jack has this option but did you try to uscrew the pad {Part that touches the truck} . lots of time that doubles the height of the bottle jack.
in my first post I said drive shaft sorry I did mean Axel.
FYI OM says under the axel.
control arm not the best place, in my opinion.
That is why I said the Jack is a Joke
In the owner's manual, it lists the rear differential carrier and the front cross member as the jacking points. It also lists several spots along the frame rails and each rear axle tube as "support" points for jack stands and/or swing-arm lifts. So those are the recommendations in the manual, but that doesn't mean they are the ONLY safe points to lift or support the 4Runner. Luckily for us, the 4Runner's frame makes it easy to find a good spot to jack without causing any damage. The lower controls arms are a good spot when you want to jack your 4Runner without allowing the suspension to extend (droop) all the way down.
You don't think you were putting someone down by saying "learn how to use the jack properly"?
What happened to him was exactly what happened to me and many other people through the years. It only happens when you use the rear axle lift points. I used the OEM jack on an OEM tire and OEM recommended lift point on flat ground and I could not get the spare on. Do yourself a favor and check your jack in this scenario to make sure you are not sucking wind on the side of the road someday.
Koz
TerryNap61
