the plan for my lift--will this work out?
NJshadow93
hey guys,
i plan on lifting the truck early 2012.
My plan:
- OME Medium Duty Kit
- These rims: Ultra Goliath Machined w/Black Accent
- and 275/70/17 BFG AT
now my question is will this all fit nicely? I have read some things where some people with this tire size had to trim while others didn't. I do not want to have to trim so i am trying my best to find a setup that will not require trimming. Thanks in advance.
Looks good to me. Those tires should fit fine, but will require some minor trimming. Also, unless you plan on adding weight to the rear, I would advise you to use Toytec super flex rear coils instead of the ome, ride quality will be substantially better.
+1
What OME spring numbers are for the "medium" kit (895e, 895, 896, ?). I have the Toytec superflex coils which are 10% stiffer then stock and IMO they are somewhat on the firm side with the OME shocks. The regular 895 rear spring is 40% stiffer and would be very firm without extra weight in the rear.
OME full suspension -- Click here for details - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
I have that size tire with Duratracs and OME and didn't have to trim, I do have a little rubbing on the inside but that's because my UCA's need some adjustment.
so you guys are suggesting i go with the OME medium duty kit, including rear shocks, but instead of the OME rear coils, use the Toytec coils? any idea on the price difference? thanks for the help guys.
Thanks. Also, can a wheel spacer be used as opposed to the minor trimming you mentioned? Or will this just create more issues?
haha ok thanks. and i hate to be a PITA but the wheels i have a link to say:
Offset: 25mm
Backspacing: 5.47"
from what I understand, these wheels will stick out a bit further than the stock 17' rims. will this solve the rubbing on the uca? or am i way off and they do not stick out further? again, sorry to be a PITA lol
