The SkylineGTRracer's 2006 build
Just the Greddy adapter for the oil filter. I'm using an Earls wide oil cooler and lines.
A Greddy oil cooler would be super badass but also super expensive. I have not seen there oil coolers in person but if their intercoolers are anything to go by then they are very high quality.
awesome thread man, I hope to rear this level with my 3rd gen i know its a slouch now but im just looking to build it to there i can comfortably throw it into a turn, some addco sway bars and some billie's/ progressive springs are on the way!
thanks. I would also recommend going with wheels and tires that offer you a wider track. there are many things you can do to make it handle better but you will need a game plan on what you want to use the truck for and then take it from there.
Well this here is the next mod.
Ramco FloMax 300 Fuel Filter Filtration System - Shop Now
A nice screw on and off fuel filter plus better filtration? sign me up.
This here was inspired by [MENTION=77471]kevinpt[/MENTION] as he put a gopro to view the rear axle. However the point of the vid was to show my friends in their tacomas with leaf springs that, imo, have excessive lateral axle moment when cornering on the track when compared to mine had none due to the 4runners lateral control arm.
And the vid.
https://www.youtube.com/watch?v=ZBr19vYrbdc&feature=c4-overview&list=UUjRB7F3jkrbSZErjtXaRa2g
as well as the others
Door view.
https://www.youtube.com/watch?v=BX8PkzpR9Jo&feature=c4-overview&list=UUjRB7F3jkrbSZErjtXaRa2g
bumper view
https://www.youtube.com/watch?v=ZzhyfA9dvgk&feature=c4-overview&list=UUjRB7F3jkrbSZErjtXaRa2g
other than that I need to save up for wheels and tires better suited to this kind of use.
Since the old battery was on its last legs I got a new lightweight battery.
New battery is 21 pounds.
Also got these beautiful aluminum sae terminals.
Now on to other ways to reduce weight. I'm thinking seats...
Did you ever get the stoptech tundra BBK installed?
No I have not. I have been using the stock caliper with good results. URD now sells a bbk using a stoptech st40 unit with larger rotors for the sport/limited 4runners.
On mod updates I also received carbotech racing pads and stoptech slotted rotors. The pad itself is a full race pad, CT doesn't recommend it for daily driving use do to dust and noise but I don't care about either of those issues. Motul 660 dot 4 is also on the way. Might also do a few mods to the suspension, engine, and alignment for the race next week.
IMG_20140318_173437319_zpskmdtq9ip.jpg~original
IMG_20140318_173529549_zpsreeq55mg.jpg~original
IMG_20140318_174029714_zps7ajclvt7.jpg~original
IMG_20140318_174020975_zpslwncufdu.jpg~original
IMG_20140318_201109766_zpsdc0afkiy.jpg~original
I'm gonna assume he used some of that high-heat engine paint. But idk. He works some crazy magic on that truck
I was thinking just some of that rustoleum manifold paint, but it has this weird, cool texture that I really Like. Maybe I'll rebuild my engine just to paint the whole block red.
You said you were the better Alex. And I disagree.
I need to pull my valve covers and paint them at some point. I really want long tubes first though.
BillM777
