This 4cyl 4Runner is begging for a 1UR-FE V8 swap
Would probably be much easier if you try to transplant a 2010+ Lexus GS motor/drivetrain vs. a tundra.
I'm with you! :snacker:
Am I being gullible or is that real. An SR5 with TE rockers and fender flares, and a 4cyl....?
Did these come with a 2.7.
BRB.......I have some interwebing to do...
Your 4WD swap 4th has me believing this is possible especially since I can find a 4cyl truck in Dallas, motor in OKC and there's a toyota ECU programmer in SA
Do it, it's not a hard conversion, aside from I know nothing about the transmission in the 4cyl
If it was 4wd, then v8 it, otherwise, what's the point?
One positive is it comes with 4:56 gears....
I was under the impression OP meant to swap the entire v8 engine/drivetrain over (hence picking the cheapest base chassis)? That's why I was saying the GX engine/drivetrain should realistically be the easiest to swap over since it's pretty much the same platform...
1) Why the hell didn't they just make the SR5 look like that in the US? Canada got it. Grrr.
2) I'd start with a high mileage TE if you are going through the hassle. 4WD swap sounds like it would be a pain in the butt.
4cyl 4Runner = $18k
TE 4Runner = $30k
TE 4R after swap = $3Xk (?)
4cyl 4R after swap = $3Xk (?)
