AntleredRuin
This is why you need an ODB2 temp reader
I got a cheap Bluetooth ODB2 dongle and the Torque app a few months ago and use the Dashboard plugin so my gauges show above my GPS on my phone. I usually just have MPGs and temps showing. Glad I got them.
Ever since I flipped my thermostat to have the jiggle valve at 6, I've had engine temps consistently between 183 and 188. Yesterday, after flooring it to merge into traffic, I noticed that my temps were rising. Within a few minutes I was at 195. I knew something was wrong, so I pulled into a parking lot and popped the hood. Of course I forgot a before picture, but there was a big ole' crack right at the top of my radiator. Coolant spewing everywhere. Well shit. Kept a close eye on the temps and drove to a Wal-Mart across the street. When I pulled in, I was around 203. Still well within the 'safe zone'.
Went into Wal-mart, got a tube of Steel Weld and a jug of Zerex coolant and patched it up. The radiator cooled enough to touch while I was in Wal-Mart, and I waited about 45 minutes to the Steel Weld to cure fully. Topped it off with the Zerex, and temps back down to 185. I made the 32 mile drive home without issue. Never got higher than 188.
It's the stock radiator and I'm at 169k, so I guess I was due. I already have a tranny cooler in bypass, so I knew that was safe.
New Koyo radiator ordered.
So all of this happened, and my dummy dash gauge did not move a bit. I forget the exact temp it starts to move, but it really is pointless. Pretty much, if the gauge moves at all above mid-level, turn the truck off, as you're already risking damaging the engine.
With the torque app, I knew something was happening 30 or so degrees before it was really even an issue. Hell, I saw temps of 203 semi-regularly before I flipped my thermostat. If I didn't have the app, I may very well have had to call a tow truck yesterday, if only because by the time I noticed the issue I was too low on coolant to safely limp to a car/hardware store.
