Those with .85 and 1.75 bilstein lifts please chime in
SoFloT4Run
First let me point out that i have searched extensively and i have not seen a clear cut answer.
Being that this would be a mild lift( no higher than 1.75) i wanted to see if any of you guys who have this left set up have had the need to install new ucas to maintain close stock caster alignment specs.
I would be using 17x8.5 wheels with 0 offset on 265/70/17 ko2s.
No need for uca is my understanding as long as it's less than 2.5 with stock alignment specs
I've got the 1.75 up front, no lift in the rear. Just about level to the eye. The dealer installed (along with a bunch of other maintenance stuff) and said they would only set the caster near 3 (just under). Rides great, 100% better than stock.
I did 1.75 setting. No issues with getting in spec. Here's my build thread...I have my alignment sheet on there. I had some slight rubbing with my tires on reverse, but nothing a quick trim of the front bumper couldn't fix.
Thanks for the input everybody. This helps put my mind at ease about my decision and not having to fork out $$$ for ucas if i really dont need to
It would be crazy if you ended up needing....
1.75 front / 1 inch spacer in the rear... stock UCAs.
AndiGarage
