Those with .85 and 1.75 bilstein lifts please chime in
SoFloT4Run
First let me point out that i have searched extensively and i have not seen a clear cut answer.
Being that this would be a mild lift( no higher than 1.75) i wanted to see if any of you guys who have this left set up have had the need to install new ucas to maintain close stock caster alignment specs.
I would be using 17x8.5 wheels with 0 offset on 265/70/17 ko2s.
No need for uca is my understanding as long as it's less than 2.5 with stock alignment specs
Sent from my SM-G955U using Tapatalk
I've got the 1.75 up front, no lift in the rear. Just about level to the eye. The dealer installed (along with a bunch of other maintenance stuff) and said they would only set the caster near 3 (just under). Rides great, 100% better than stock.
I did 1.75 setting. No issues with getting in spec. Here's my build thread...I have my alignment sheet on there. I had some slight rubbing with my tires on reverse, but nothing a quick trim of the front bumper couldn't fix.
Thanks for the input everybody. This helps put my mind at ease about my decision and not having to fork out $$$ for ucas if i really dont need to
It would be crazy if you ended up needing....
1.75 front / 1 inch spacer in the rear... stock UCAs.
Crookedcat
