Those with Limited's, answer me this
Lunchbox
I was going through the 4R interior options on the Toyota website and it states that "Illuminated instrument cluster gauge needles" are standard on the Limited. What exactly does that look like as compared to the regular needles on the SR5 and Sport?
our needles light up and has a red beam that shines onto the side so that light will move according to how fast you go.
Drive both the Limited and another model. You will see the difference. I don't know if it's a single good enough reason to get a Limited over a Sport or SR5, but the gage needles are very visible. The light shines through the red plastic needle and makes a red spot on the dial wherever the needle points.
There are some pictures in a few threads, do a search to find them.
Limited has "Optitron" instrument panel. It lights up as soon as you start your engine. Looks fantastic. I really like it, especially when driving and entering tunnels, passing under the bridges or just in cloudy weather, all your gauges and needles are perfectly visible.
Re: Re: Those with Limited's, answer me this
so does all the other model but without the red needle.
All three trim levels have gauges that are always illuminated (I believe this started with the 2004 models). I don't think these are actual "Optitron" gauges like those found on a Lexus or the '05 Corolla LE, '05 Camry, and '05 Sequoia Limited (among others).
The 4Runner definitely does not have opitron guages. Optiron guages are much more vibrant and you can't see them when the engine is off. The 4Runner's guages only have the backlight stay on all of the time. Instead of the dashboard being lit up only when the headlights are on, it stays on all of the time for better visibility. It is kind of hard to explain the difference between the 4Runner's guages and opitron guages. You really have to see it to understand it.
I know what Optitron is. Just it's looks like it, without disappearing at all after engine is off.
So differences between trims are needles. I didn't mention it before. Nice. In this case Toyota could do full Optitron for Limited :)
No, the design of the guages themselves, particularily the speedo, is different as well.
Look at the link that CopperX posted above to see the difference.
Yes. Sorry, forgot about it. Thank you for reminding. Limited gauges looks much better.
