Tint on my Black LE
Reddogredi
I am planning to add some tint to my windows and was curious if anybody has used any of the shops in the Hampton Roads area of Virginia.
If so, let me know if you recommend anybody or know the ones that I should stay clear of.
Thanks.
:thumb3:
I got mine tinted at Express Tinting at the corner of Holland Road and Lynnhaven Pkwy in Virginia Beach (inside the Car Spa car wash). I was in and out in about 20 minutes and the tint continues to look great nearly two years later.
I just got the front two windows done to match the back windows. Not exactly sure what percentage that is. They will tell you that it is not legal in VA, but I got it done anyway and have never been hassled for it.
I think I paid around $70, but there were some cheaper and more expensive options.
I got mine done at this place, too. Took a half hour and they did a very good job.
Thanks for the reply. This helps. Its good to know the work they do will last.
I didn't go to that place.
Dynamic Car Audio & Security - Home
That's where I got my tint done, and they take probably 25-35 minutes to complete depending on your job. I got mine 20% front with limo tint in the back which was $200 total for me. Only because the film they use is quality, so it's more expensive. I've had them tint my other truck before, and I've never ran into problems with 'air bubbles' so I went back to them again to have them tint my new 4R. Virginia Beach police (select few of them) will pull you over if you have limo tint all around. Most of them don't care about you having 20% as long they can somewhat still see you so 20% is good enough. For rear windows, they don't care but they can legally use your rear tint as a reason for pulling you over if they think you're driving with weight or you're driving erratically. I'd pick this place over any other places any day, even if it's more expensive. I get my money's worth.
Your factory tint is between 23-25% so they used 20% to match factory tint.
Thanks Hokie. I actually work right near Dam Neck so that might be a good spot to start. My only issue with the fronts are I live next door to a Norfolk police officer, but we are friendly so I don't think he will give me a hard time. I know VA has fronts at 50%, but I want it to match the back so I will get it to work. I don't think I will have an issue with the Fuzz.
Are you a fellow Hokie or a Hokie Alumni? :D I'm still enrolled at VT. I see. If you guys are on good terms & you both respect each other's privacy then there shouldn't be any problems. The thing is, legally he's not allowed to give you a ticket for the tint if your truck's parked. He has to catch you committing a moving violation which in this case would be a tint violation. If you're just looking for a little bit of privacy, then go ahead and do 20% front windows only. You'll have no issues seeing through at night, but you will be seen from the outside. It's not as dark as I would prefer, but only because I feel more secure with 3% when no one from the outside can see me. I don't know why, but I just do. You'll be fine with 20%, definitely.
Also, I think the price for the front windows might range anywhere from $90 to $100...not sure about 20% front only. I've always had mine tinted all around 3% and 20% front 3% back
Sounds good, thanks for the info. Me and the neighbor are cool so it shouldnt be an issue. I'll probably get whatever the front needs to match the back. Do the police make you take off the tint when they pull you over or do they just give you a ticket?
I'm a JMU alum from '04, but I have a ton of tech friends from high school and work. Go hokies! Bleep wahoohs! J/J UVA.
Solid. If you visit that place, all you need to do is walk in and let them know that you would like to add 20% tint front windows. It shouldn't take too long, maybe 30 minutes or less. However, they do keep a schedule of appointments they are supposed to handle so if you have a busy schedule then you should call their workplace to schedule an appointment where you would like to add 20% tint.
Solid on JMU. I'm still annoyed about our home loss to JMU two years ago. Screw UVA, but I have plenty of friends that's currently enrolled at UVA. The rivalry between both schools help 'spice' things up in our friendships!
They will pull you over, and they will use a device called Tint Enforcer. The device will help the police determine the tint % that is on the windows. I've gotten pulled over, and they found my tint to be 2% and 3% (two separate occasions) so the meter is 99.9% accurate, I guess. They will cite you a traffic infraction, which is a pre-payable offense. Basically you have two roads to go down from there... first one is to pay the ticket and continue driving with the tint but the catch is that you are still at risk for getting pulled over again due to illegal tint. Second road would be you taking the 4R back to the tint shop where they will take it off. However, you will want to get a written certification from them saying they removed it themselves and they confirmed that there are no illegal tint installed on your vehicle. Only because you will want to take that letter to the court on your court date and show it to the Judge. From there, he will dismiss the case and you can go...happy, I guess. I wouldn't be happy, 'cause I care about privacy and security of my vehicle.
For me though, I got pulled over three times and I've paid the tickets every time. $96 each, but they increased the processing fee on the website so my last tint ticket was $98 total.
Someone here on the forum pointed out a certain excerpt from the VA law code where frequent tint tickets can turn from a traffic infraction to a misdemeanor. He basically said I got lucky I wasn't charged with a misdemeanor because I had three tint tickets and they all were considered as traffic infractions. I don't know how many tickets they require issued before they charge you with a misdemeanor the next time you get pulled over.
Good luck hopefully I answered all of your questions
Jesse1
