Tire Pressure Sensor Problem-Need Help???
rook said:
this mod is reversible. i have since wired in a switch which allows me to use the system half the year.
ric,
the module should be below the glove box. there are 2 screws holding the black plastic panel in place, drop the panel and it should be there
Hey Rook, Im so sorry I didnt thank you sooner, so Thankx :bigok:
Other option
If you notice pin 16 is ground so its possible to just jumper pin 6 to pin 16 on the circuit board. That will ground out the signal as well. I did that and it works as permanent bypass. 10 year old car has 5 bad sensors so TPMS will be disabled from now on.. I can live w/o it..
I know this is a little old, but...this seems like the simplest way to go about simply turning the TPMS off permanently. That said, how do you "jumper the pins"? Simply run a ground wire from the 6 pin to the 16 pin? And we're talking about the red ECU, yes? Sorry for being a little dense.
And if you happen to have a pic, even better :madgrin:
Mike Sargent
