Tire Question
SurferRob
I am getting to the point where I need to get new tires for my 2011 SR5. Currently I have the stock Dunlops. I am leaning towards the A/T Revo 2. I had the Revos on my last 4RUnner and liked them a lot.
From what I have read on this forum, upgrading tires can help with nose diving since the sidewall is stiffer on better tires. I don't know a lot about tires, there is a lot I don't understand.
Here is my question: Would getting the load range E be overkill considering I don't tow anything? I assume the E is stiffer for towing? How wrong am I here?Or would it be worth the extra money to help with the nose diving?
Thanks in adavance.
There will be those that tell you that you need them. For heavy off-road and overland use, then the thicker carcass will reduce flats and punctures. They will ride stiffer, because there is less flex to go around, at a significant cost of rolling weight.
In terms of specifications, even with P series tires the tires can carry 130%+ of the GVW - that's gross vehicle weight, the maximum it's licensed to weigh.
Thanks homey. I didn't even think about the extra weight. I don't do any off roading, so I guess I should be leaning more towards the regular A/T Revo's instead of the E rated Revos.
I'd say - yes E tires would be an overkill. C load @36psi will handle fully loaded T4R just fine. E tires are stronger but heavier. As I see it E load is a requirement for full size trucks like Ford F-250 for example. Lots of people use it for rock crawling because E tires have stronger sidewalls. I don't live in desert with many sharp rocks, so I got myself C load and so far they handle everything well.
http://www.toyota-4runner.org/perfo...re/89432-ongoing-review-revo-2-lt-load-e.html
Be advised, it's probably way more than you want to read, but if you're interested in that tire.....
Nothing about nose dive, though, and I don't tow, but the load E would definitely provide more side stiffness for towing. I need to update that thread soon, as I'm getting very good tread wear out of them. Significantly more than the estimate made in the thread.
