Tires & Lifts
walderc
Okay I just recently got a 93 4runner 3.0 V6 auto and am thinking about getting some new wheels and tires... This creates a problem cause I wanted to go with 33x12.5 but cant find a body lift to do it, so I am wondering if 31x12.5 would fit under a stock lift? Also is there a leveling kit or something that would bring the sagging back up on the 4runner?
Best fix for the saggy butt syndrome is new springs, and since you want 33's, a suspension lift will take care of both.
x2
Put an OME suspension underneath it, or something similar. Body lifts cause all kinds of collateral issues.
why cant you find a body lift? it is actually pretty much universal. you can do it the canadian way, and use hockey pucks. im not totally sure, but the 31's will fit. but the 12.5? why that wide? im again, not totally certain, but 12.5 will rub like nuts. for the body lift, figure out how many body mounts you need, and find a kit that has that many, and go at er. are you sure that its not a suspension lift you are thinking of? try harder to search, because you wil probably find what you are looking for. good luck. ohh, and if you are at al welding and machining wise, you can custom make your own body spacers out of aluminum with a hole drilled in the center with a lathe. either way man, i am in the same boat as you with the saggy runner. im just gonna add a leaf.
workingwheelswnc
