tires
nmwolfer
I have a 2002 Toyota 4runner SR5, it does not have a lift on it, will these tires fit
Kenda Klever M/T KR29 265/75R16 123Q
I have Kendra's on my side by side and they are an awesome tire
I know lots of people that have 265/75/16's on with no lift and little to no rubbing.
I personally have 265/75/16 Duratracs on mine but I have a 2.25" suspension lift so no rubbing
They should be fine. if it rubs a bit you can always pick up a .5" BL
I met 285 not 265
As I just bought tires this week, I would completely advise against 285's without a lift. They might fit, but as soon as you turn the wheel, they'll rub and will either damage the tire, the fender, or both.
In fact, 265/75/16 is about a 1/2 inch bigger than the stock size and might rub a bit.
My best advise is if you want to go with a bigger tire for ground clearance, then you need to consider a lift.
Jkmazon
