TNF/SRQ 3rd gen 4runner Hybrid Front Bumper
SRQ-Runner
96-02 4runner Hybrid Front Bumper
Price: $825 shipped to lower 48
Order here: https://www.srqfabrications.com/product-page/96-02-4runner-hybrid-front-bumper
If you've been trying to find a great looking quality bolt on bumper for your 3rd gen 4runner look no further! The new hybrid design is stronger, more lightweight, and offers the best approach angle of any other of bumpers to date. Not to mention it looks badass!
We wanted to be able to offer the best fitment possible so we took our designing a step above all the other fabrication companies out there and had the front of the truck laser scanned! This allows us to model the bumper within our CAD programs using a virtual representation of the truck that is accurate to within .005 inches!
The frame mounting plate, winch plate, and skid supports are all 7 gauge HRPO steel. The main vertical supports are 3/8” thick steel. Shackle mounts are 3/8" steel with 1.5 OD .250 wall DOM tubing welded in. All other sheet metal parts are made of 11 gauge HRPO steel. All tubing is 1.75 OD 11 gauge ERW steel.
The bumper was modeled around a warn m8000 winch that has a 10" x 4.5" mounting pattern and centered fairlead/spool. Other winches may fit (similar size and mounting pattern required). Depending on the winch size you will possibly need to detach and relocate the control box.
We realized that these bumpers are going to be mounted on 20ish-year-old vehicles and the chances of each and every one of them having a perfect frame with no previous front-end damage are slim. So in order to offer the best fitment possible, we made all the mounting points slightly oversized. This will give you a little adjustability when mounting. New bolts and washers are included.
In order to get the tightest fitment and strongest mounting design possible, there is some modification required. You will have to trim 2 inches off the front of the frame rails on the vehicle. This will not reduce the integrity of the frame. After cutting, clean and coat the cut area with some spray paint to prevent any rust issues.
There are holes for 3/4" flush mount led lights on the outer corners of the bumper. Amber LEDs are available for purchase or you can supply your own. Please note that LEDs will cause hyper flash if you do not add a resistor to the wiring or change out your flasher relay (recommended).
Options:
Fully Plated
Open Wing
Dang it lol I literally just ordered my front bumper. This seems cheaper and looks better.
Side question: I like your grille. Is that the same size as the stock grille? Any idea where I can get it?
