Torque app profiles
Hi,
Anyone know where I can find profiles for Torque App... T4R V6 2006
Regards
Juan
Maybe no one is exactly sure what you need but here's some info (2006):
The 4Runner's standard 4.0-liter dual overhead cam (DOHC) V6 engine produces 236 horsepower, with 266 lb-ft. of torque at 4,000 rpm. The available 4.7-liter i-Force DOHC V8 produces 260 horsepower, with 306 lb-ft. of torque at 3,400 rpm. In both engines, variable valve timing with intelligence (VVT-i) helps provide substantial low-end and mid-range torque. An electronic throttle control system with intelligence (ETCS-i) helps optimize performance and fuel economy.
Gross weight 5330lbs
Fuel Capacity 23gal
Engine 4.0L
Max RPM 7000
Fuel Petrol
That's all you will really need, the rest can be google to be exact really. Is this what you mean by profiles?
Fuel Capacity 23gal
Engine 4.0L
Max RPM 7000
Fuel Petrol
5330lbs!! O.o what do you have on your truck??!! These weigh 4550lbs stock. That's with the V8, the V6 is 4325. These are for the 4x4 versions. The 2wd versions are close to 200lbs lighter too.
AndiGarage
