Torque Specs
amnt
I am planning on adding a BOSS lift this weekend. Where can I find the bolt torque specs for the suspension parts? I want to make sure I get them set correctly.
Stabilizer bar to knuckle 52
Stabilizer brackets to frame 36
Shock top nuts/bolts 47
Shock bottom bolt 70
Lower ball joint castle nut 103
Lower ball joint attachment bolts 118
LCA adjustment cams 129
UCA to frame long bolt/nut 85
Upper ball joint castle nut 82
All values in ft/lb
Make sure to remove the ABS sensor wire and tuck it up inside the engine bay before you start taking anything else apart. Very common for it to get stretched/broken and it's not cheap.
All values in ft/lb
Very good info to have!
