uh oh, here we go again...
base stocks - blends - the zero in the weight - additives
soon we will all be oil chemists, and someone will offer us some Amazzoil
Mobil1 - 0W-20 @ Walmart- gallon jugs. Save yourself some $$$!
On Bob is the Oil guy (BITOG) the skinny is that it's a Type III base, which is a synthetic base derived from dino oil. In the US this can be labeled 'synthetic' but in the EU it's a 'semi-synthetic' or 'synthetic blend.'
But that's a technicality.
Use with confidence, based on the analyses posted on BITOG it's probably the best 0W20 on the market in terms of both cold flow and hot viscosity performance, with only the Honda 0W20 coming close. Mobil 1 does better from -20F on down when cold, if you care about that sort of thing.
THX for all the info,for the price,I suspected it was possibly a "Blend",and not a "Full
Syn",considering Mobil 1 cost more,they should really label it for what it is...as for
Engineer....as long as I can take the "Plastic Cap" off,without boogering it up,I might keep it:biggrin2:
The price difference between group III, IV, and V base stocks is not nearly as high as it used to be. Even Mobil 1 branded synthetic oil is now likely a blend of the three. In terms of quality, lubrication properties, or oil change interval, they are for all intents and purposes identical given the same application and additive package.
BTW, the "plastic" oil filter container on our GR1-FE engines has a drain plug, which makes the whole oil change a lot less messy. It's better, not worse, than metal canister types (unless the oil change pit monkeys at the dealership do to yours as they did to mine). Kind of like how Glocks are generally more reliable than 1911's, it's called progress. There, I said it.
ETA: And while we're on the old school vs new school subject, 3000 mile oil change intervals aren't necessary either![]()
i've used Mobil 1 for my last two oil changes, but after reading up on the Toyota 0w-20 synthetic on Bob Is The Oil Guy i bought a case the last time i was as the dealer parts counter. at $68 it actually cost me a little less than Mobil 1, when you figure it takes 2 single quarts + a 5-quart jug per oil change.
and just to clarify Antman, those were the 0W-20 prices, right?Not to beat a dead horse... Here I stand at Walmart.
Mobil1 0W30- 5qt jug- $26.48
Mobil1 0W30- qt. - $ 6.47
(x2) - $ 6.47
....................$39.42
$68 or $40. I'll stick with the Mobil1.
doubtful. as evidence to the contrary, i refer you to your build thread. :cheers:Yes :redbrick: edited post. Like I stated- Idiot.
Well, a friend just let me in on a little secret. The Toyota oil is $68 for 12 qts(case). My bad- the prices are just about equal. I am an idiot.
Carry on!![]()
$68 was the price the guy at the parts counter gave me. YMMV.From the guys selling it out of the back of the Mechanicsville VA dealership?
I am down there every month, and apparently they won't sell for that price direct out the door, and want $20 shipping:
Genuine Toyota 0W20 Full Synthetic Motor Oil 12qt Case | eBay
And no, you're not an idiot.
