TotalAutomotiveLV
We get a lot inquiries about the
Stage 1 and Stage 2 kits
from ICON Vehicle Dynamics and
what is the main difference.
Stage 1 Kit – K53061
The Stage 1 system works well in most on and off-road scenarios by significantly improving factory body roll and overall driving ability. ICON 2.5 Series front coilover shocks feature a vehicle-specific tune to give your Toyota 4Runner great ride quality on or off-road, and they are adjustable from 0 to 3" of lift.
SYSTEM COMPONENTS:
Part #58646 - 2.5 SERIES IR COILOVER KIT
Part#56505 - Pair REAR 2.0 ALUMINUM SERIES IR SHOCK
Part #52700 - REAR 2" SPRING KIT
Stage 2 Kit – K53062T
This ICON Stage 2 suspension system uses the same components as the Stage 1 system with a few simple changes and additions. The 2.5 Series coilover shocks used in this system are the Extended Travel version, offering increased wheel travel that will enhance your on and off-road performance even more so than the standard travel units. Since these shocks do provide more suspension travel, they require the use of an ICON upper control arm. The tubular steel uniball upper control arm kit found in this system offers improved articulation and strength over the OE control arms, and has alignment correction built-in.
SYSTEM COMPONENTS:
Part #58647 - EXT TRAVEL 2.5 SERIES IR COILOVER KIT
Part #56505 - Pair REAR 2.0 ALUMINUM SERIES IR SHOCK
Part #58451 - TUBULAR UCA KIT
Other options for both the Stage 1 and Stage 2 Kits:
Part #56100 - ICON Rear shock shin guards
Part #54000 - Billet lower adjustable link arms
Part #54100 - Billet upper adjustable link arms
Part #54200 - Adjustable track bar
Part #52800 - ICON Overland Series dual rate 3" lift rear coil springs
Part #56104 - Rear hydraulic bumpstop kit
Part #191011 - ICON tubular uniball upper control arm cover caps
Part #198000 - ICON 2 pin spanner wrench
SYSTEM COMPONENTS:
SYSTEM COMPONENTS:
