TPMS (tire pressure monitor system) DISABLE For 5th gen
05Rrunner
Hi All,
Does anyone have the wiring diagram or already attempted to disable the tire pressure warning light on a 5th gen ? . I did the mod on my 4th gen (thanks to T4R.org) and it worked out great, but I believe the 5th gen is different.On my 2005 I had to ground a wire behind the glove box to disable. I also added a switch so I could have stock function or off.
before flame please read :
1) Why do you want tpms light off ?
Wheeling in dunes,Pismo,Glamis etc.wheel and tire change,I maintain proper air on my own without the reminder.I want to.
2) Ways I do not want to disable light. Cover with tape,remove bulb/led,smash with hammer,put all sensors in spare tire,put all sensors inside small tire hidden in vehicle.
3) I did use the search function.
4) I will have pictures of the mod if anybody wants them.
Thanks for any help and I will share any of my findings or attempts made to help anyone else who might want to do the same.
Rob
Can't help you with the mod as I've just learned to ignore the light when I'm aired down, but here's a link to Nashman's manuals including the wiring diagrams if you don't already have it:
My Files
Smokepole1
I am a new owner/forum member of a 2013 Toyota 4Runner 4x4 Limited and the manual saids that one can view the tire pressure of each individual tire by pressing the Car button on monitor but I do not have such a button. The dealer tells me that the model I have does not have that capability. Any information on this?????
After the TPM light warned me of a damaged and dangerous tire while driving at 80mph with my wife and daughter on I-5, I don't recommend disabling the system permanently. Sounds like a competently installed switch would be good for owners who air-down.
Not sure it will help but the TPMS sensor's location is back near the spare originally held up by a bracket. I moved mine but you get the idea.
CupHolderTPbracket2.jpg~original
Any updates ?
Hi all,
Was wondering if anybody could help with a wiring diagram for the 5th gen. The module is located by driver kick panel.
