trac light on after lift
hyphen
i got my lift installed in june along with 275 tires and a uca. after the install the trac lights remained on. installers said i gotta check with the manufacturer, dealership tells me i gotta talk to the installers. toyota techs said the truck is running fine though.
anyone have an issue with this?
Same happened to me after LCA installation. Zero point fixed the issue. Get it fixed as soon as you can because it can be dangerous if you need your stability control in an emergency situation.
If the ABS light is also on with the Traction control light, I second the stretched ABS line. This is an easy fix. Techstream at the dealer will tell you which line is stretched. Order the part for around $55 from Camelback Toyota and swap it out at home. Once I swapped mine out, all was well.
delislerebecca
