A alfonzo New member May 12, 2015 #1 After installing 4.56 gears and ARB front locker, the traction control and 4wd lights are on and flashing. What can be causing this? thx
Seattle206 Senior Member May 12, 2015 #2 Your system is disabled and cannot use those features. You need to do the YAW calibration tweak. http://www.toyota-4runner.org/5th-gen-t4rs/191444-new-abs-harness-yaw-calibration-none-work.html Last edited: May 12, 2015
wfo9 New member May 12, 2015 #3 Could be several things... Did you hook the ADD harness back up properly. Also, sounds like the old speed sensor wire problem. Very common for one to lose connectivity after any type of install. Test those with a multi meter.
A alfonzo New member May 12, 2015 #4 Thanks for the quick replies. I forwarded them to my mechanic. I will report back. Thanks again
