Tranny cooler suggestions
I believe that I read where some of you have the oil coolers installed and in the winter you have them on bypass. Can you give a picture of your install? What or how do you bypass?
B&M 70268, with Scangauge II to monitor. I'm usually running 140-170, and have only touched 180+ a few times in town.
Scan gauge ll is that reading radiator temp ? I use a bluetooth odb2 and torque pro app only let's me see radiator temps. Here's my install
I've got the sending hose on top and return line on bottom mounted sideways. I had to take off the fan guard? The big plastic thing on the radiator to get my zip ties good. I'm not mechanically inclined only took 1 hr to do. Had a hard time getting hose off the steel lined so I took razor and just cut them at the steel line so much easier then trying to pull off.
From Trans should always be bottom line when mounting sideways. Top should be return to Trans
I have a question, I haven't installed my B&M Transmission Cooler yet. I was wondering when you do, you're going to lose some transmission fluid. Did you guys topped it off afterwards?
works fine
I installed B+M last year but performed and engine replacement this Spring and placed a second cooler, as I tow a sportboat. Temps are acceptable now as I installed a gauge last year and monitored temps... I have no complaints now through boating season!
