Transformed..... Decepticon...lots of pics
gshadow325
Finally figured what to do with the empty toyota ovals front and rear. I hate logos. I like to be anonymous :)
FYI: Oem logos just pop off
Popped them off, Popped off V8 badge too of front grill.
Had some 1/8" abs plastic sheet lying around. used the two emblems as a template and cut out these ovals. one for front and one for rear
threw some 1" strips of 3m double stick tape
then stuck it over the oem logo
Add some heat to promote adhesion :)
Then go to you vinyl sticker machine and load in some white reflective advery vinyl. click on the decepticon clip are you have..few minutes later you have this..
flash on to show off the reflectiveness (is there even such a word?)
[URL=http://s216.photobucket.com/user/gshadow325/media/Toyota%204Runner%202003/20130828_172024_zpse3b7b2e5.jpg.html]
20130828_172038_zpse530bd26.jpg~original
[/URL]
should made the base sheet out of clear and black out the sides, then apply the logo, throw an led behind it and itll stand out.
hmm, on that note, i think the next version will be what you said. i am going to make it with clear abs plastic stick the same decal on it with the exception i will used the inverted picture so the white will be the clear part.
The only reason I didn't like this was because you chose the wrong side. :P
there is a FJ Cruiser with a autobots one near me. black, 3" lift, and rolling on black 24" wheels
utkrstam
