Transmission Fluid service
I know how to do it.....and maybe if you're 5'5 and weigh 150lbs...there's room to crawl...but sadly I'm NOT....
Being 6'3 and 225..it's a little tight.
Sorry Mike, I was referring to OP bobdod04. Wasn't intending to patronize.
Although...I am 6'2", 210, and I fit under there. It was tight, but doable. I have ramps I use when I change the oil, but I didn't need those. I suppose you could put it on 4 jackstands (to keep it level) and get some more clearance.
I've been under there to do the transfer case and diff fluid, but its no fun at all. I guess I'll try and do a drain and fill the next few oil changes.
scottji...No offense taken....
I only have the service done every other year...for $80..it's well worth NOT getting under the truck...Royal pain.
kimyuseung77
