Transmission interchangability
Can't help you with which Sequoia transmissions would work, but I can tell you what I learned during my 2WD to 4WD conversion on my 2001. I couldn't find a good 01/02 version, but I was able to swap the internal valve body from my bad 01 transmission into my 'new to me' 98 version.
The 96-00 versions use a throttle cable. The 01/02 versions use a solenoid for line pressure control instead of a cable. When you swap the internal valve body into the pre ‘01 transmissions, it converts them into the 01/02 electronic version. Finding a 96-00 transmission is way easier!
The following link describes it all:
Converting 95-02 Auto Transmission to 03-04 | Tacoma World
Hope this helps.
Hope this helps.
What did you do with the throttle valve when you put the newer valve body on the older trans? Wire it WOT?
Once you swap the valve control body from the 01/02 into the tranny, it comes with the wiring harness so everything connects as it was before. I hope this answers your question. The link provided gives all the info.
tssawlson538
