artstar1983
Junior Member
Hello everyone,
I have a 2010 SR5 that I am having the following issues with. I was hoping someone could tell me if they are experiencing these issues as well.
First, after I am sitting at a red light with my foot on the brake and I lift my foot off of the brake to hit the gas the transmission makes a “clunking” sound. The sound and the feel is similar to when you shift the truck in and out of Reverse, Neutral or Drive. This does not happen every time but happens frequently. Also, on rare occasions it appears that the truck is slipping out of gear but I have not been able to confirm that.
Second, I recently had an opportunity to take it off road. During a downhill descent I decided to use the automatic down hill descent feature. It seemed to work well but made a lot of clicking and snapping sounds as I was descending the hill. I looked it up in the owner’s manual and there is no mention of any such sounds so I am a little concerned that something was not working correctly.
Finally, I am experiencing an issue where the truck does not want to be shifted into low 4WD. I will shift the truck into park, and the 4WD lever will simply not be budged into low gear. The dashboard displays an error message suggesting that the parking gear will not engage. After combinations of shutting the truck off and playing with it over and over I can usually get it into gear. However, sometimes it pops out of gear and the gears grind in the process.
I am planning on taking the truck into the dealer this week to have the issues addressed. However, I would like to go in informed if others are having similar problems.
Has anyone else experienced these conditions and if so did you have any luck getting them addressed by Toyota?
