TRD running boards on Limited
enolasfinest
Has anyone modified the running boards from a TRD/Trail so that they will fit on a Limited? I believe all this is needed is a spacer to hang the running boards lower so they clear the Limited's rocker panel.
Thanks.
Thanks.
You could probably do a spacer, something like this...
http://www.toyota-4runner.org/5th-gen-t4rs/107396-**ride-spacer-kits-run-nfabs-your-sr5-le**.html
Or you could cut the rocker, as Antman has done, or even replace the rocker with trail rocker like this...
http://www.toyota-4runner.org/5th-gen-t4rs/150296-2014-trail-rocker-trim-12.html
