TRD Tacoma Suspension + Tire Size
CT-4runner
I am looking at swapping in a brand new take off 2014 Tacoma TRD suspension into my 4runner to replace my leaking XREAS suspension. Seeing as 265/65/18s fit under the OEM sagging suspension. What would the the biggest tire size I could run with the Tacoma TRD suspension?? Not looking for anything massive, just something that would look better than the stock tire size on the 18" wheels
2012 trd tacoma shocks and 1.5 inch spacer
265/75/16 BFG rugged terrains
good choice of tire
im running the same tire as above but 255/70/18
stock
IMG_20140321_131046_zps1e185998.jpg~original
trd offroad coils on 5100's set at .85
I'd say that depends on if you're just putting on the front struts and rear shocks, or adding spacers on top of that suspension.
Yea like mentioned above it depends on if your going to do a lift as well
i have 2014 Tacoma Trd suspension and a 3 inch lift.... I'm currently running 265/70/17 terra grapplers.
Before the lift the rubbed slightly at full crank. Now they don't rub at all.
Another huge factor is if your going to use stock rims or wheel spacers... Bigger than 265/70 will sometime rub on the uca"s but if u get spacers or a different offset wheel u can run more tire.
