TRDTeen '99 Limited Build Thread
Doubt it. There wasnt much at HJ. A few puddles here and there. The mud picture you see above is on Avery near the train tracks. When we go Sunday, we'll try to find some mud(;
Haha, if anything I'll mix some dirt and water and slosh it onto my car.. need to have my first day back at school on monday as impressive as possible.. :flypig:
your car it self isn't impressive impressive enough? ;)
Hahah, I love it as it is, but it really would be nice having that transfer case lever. Its alright though, im planning on plastidipping the fender flares and bumpers soon. I just did my grill today and im sure it will look sick.
Still need to get around to doing that. (problems of being 17...:ohwell: )
That's not mud, that's some sludge right there! Good stuff Matt. So when are the Robert & Rob clear corners getting installed? LOL
Actually got them on today. Was having so much fun doing modifications to the car I forgot to take pictures haha! They look great though, a little dull when the light is on. I'll get some pictures up soon. Thanks for the sell!
Small update. Got clear corners on and prep work to install my cb.
Took out the plastic dash piece to dremel the ash tray. Then wired the coax cable to the rear of my car to the antenna. Ran the wire behind the dash and under the brake and gas pedels, then continued under the door panels to the trunk. Had it go through the little plastic piece in the back if the drivers side. (That plastic box that pushes air out when you close the doors...).
null_zpsf84fcf43.jpg~original
null_zps0a3b767f.jpg~original
null_zpsc1f25e45.jpg~original
Clear corners.
null_zps90f3c494.jpg~original
The corners look dope! I still have the clear bumper lenses if you want them.
Make sure you don't coil up the coax anywhere, coiling the cable will destroy the signal.
Looks good bro!! We'll get tuning soon!
I would advise running that coax another way. If you drag the bumper, you will cut the coax.
Looking good.
I will, going to run it under the bumper and out the corner between the headlight and black plastic bumper piece.
i love getting goodies when i get home from work. Got my antenna stud and led's for the cluster gauge, climate control, key ring light, and cig lighter.
null_zps036fb443.jpg~original
null_zpsf12e9ae4.jpg~original
Are the 99 and 00 limited CC, and cluster the same? If they are then those are the wrong bulbs :l
if not its okay, ill just order the right bulbs next time :)
Heh, yea. Hopefully these were too much.. i pick up all my leds off ebay.. i believe the ones you need are the same as mine.. they are neo-wedge bulbs: T3, and T4 i believe.. Ripcord has a chart somewhere around here.
I'm pretty sure you use 3 194's for the cluster board and 74's for the climate controls, cig lighter, key ring light, and ash tray? The neo wedges are for the clock or something. Not sure if thats correct though.
I believe thats for non-limitted as per Ripcord's Chart.
The chart is in the "Buyer's Guide" stickied thread at the top. :thumb3:
LED4runner.png~original
The clock color cant be changed and you can only put a film of purple transparent plastic to make it seem white.
wayblom
