Trimmed limited flares for wheel spacers
Jaketino
Simple as the header. Post up some pics of how you trimmed your limited flares after putting on wheel spacers. I'm trying to get an idea of how to cut them tomorrow so they don't catch my tires when I turn.
THANKS!
Stock and 1.25. Hoping to get a 1.5 body lift soon and then LC 8 wraps and Toytec after I finish paying it off.
You wont need to cut for spacers if you lift with 265 tires. I would just remove them till you need them. Like when installing some 33's or larger tires.
I need them for the TBU that will be happening this weekend. I don't really care about those little flares. They will be replaced with a front bumper anyway.
Should've explained a bit better. It is rubbing on the limited flares here:
It is also rubbing on this bolt, but really only when I crank it really hard, which is not often.
I figured I'd take the dremel to the bolt and round it down a bit and then cut where needed for the front. I was just looking for ideas on how to cut it/angle. I have 265/75/16 duratracs but no lift.
emilygrace28
