Trying to Fix Aftermarket Fuel Gauge - Ohms?
Lunch-Box
Hey...my new-to-me Runner (1985 22rte) came with a GlowShift fuel gauge since the previous owner swapped to a digital cluster...in which virtually nothing sync's up. Anyway, the fuel level gauge isn't working, and I suspect the empty/full ohms may have been selected incorrectly. However, I cannot find the correct specs for the ohms for the fuel level sensor.
Anyone know where I can find the empty and full ohms so I can set this gauge up?
Thanks!
Hey...my new-to-me Runner (1985 22rte) came with a GlowShift fuel gauge since the previous owner swapped to a digital cluster...in which virtually nothing sync's up. Anyway, the fuel level gauge isn't working, and I suspect the empy/full ohms may have been selected incorrectly. However, I cannot find the correct specs for the ohms for the fuel level sensor.
Anyone know where I can find the empy and full ohms so I can set this gauge up?
Thanks!
Try this .pdf from GlowShift --
http://www.glowshift.com/instructions/Digital-Series/GS-D02W-Wide-band-AirFuel-Gauge.pdf
:rockon:
Thanks...I actually have GlowShift's .pdf for the fuel level gauge pulled up, and there's a chart to identify what ohm load indicates empty, and full...with values between registering the amount of fuel in the tank. But that's the issue...I can't seem to find the ohms for the OEM fuel level sensor.
In other words...I have no clue how much gas is in the tank! :(
