Tundra Brakes Upgrade - is this kit compatible?
I think the ABS issues are on '96-'98. IIRC, the 231mm exacerbates the issues, while the 199mm stays the same.
I think the ABS system was redesigned for '99+.
All ABS parts for 1996 to 2000 are the same. The introduction of VSC in 2001 required a completely different ABS system.
Also, I recommend the Callahan calipers, but not rotors and pads. I already warped them. I've been running Brembo blanks with Axxis Semi-metallic pads for longer in another 4Runner and they stop beautifully.
So you’re not seeing a problem running the 231mm upgrade? I have a 2001 and was wondering if this would be a problem. I also have the 5-star 16” wheel, do you know if these wheels will clear the calipers? Thanks!
Well then my '99 has the 'original' ABS system (pre-redesign), and I have 231mm calipers with no problems. Of course, I also live in Houston with really no snow or ice to speak of, so my experience may be biased.
Do you mind if I ask what wheels you have and what size? I'm interested in doing the 231 upgrade but nervous that they won't fit with my wheels.
Glad to see another Houstonian as well!
I have the stock Limited aluminum 5 Stars. The ones on the Limited are 16", and fit fine, no spacers or grinding needed.
I think there are some 15" steel 5 stars, but those came with the Base or SR5. These do require grinding or spacers, as do all 15" wheels used on the 231mm.
There's a picture list floating around somewhere that shows which stock Toyota wheels will fit which calipers, but you'll have to Google for it.
Welcome!
Sorry, I wasn't specific enough. I run the 199mm. Your 5-star's will clear the 231's. I'm running split spokes so I had to go with 199mm's. I have no experience with the 01-02 ABS system other than with stock brakes, but I haven't heard nightmares.
I have a 2002 (in the 2001-2002 family things regarding ABS/brakes) and I've been good. I've been running my TBU for over 3 years now.
I have OEM sequoia calipers with EBC rotors and EBC green stuff pads.. My only gripe is how much brake dust the Green Stuff pads throw out. way too much. I will got all OEM rotors and pads for my 2nd 4runner (it's a 2000).
I'm also running Sequoia 231 on 16" 5 star rims. The steel spare will hit/grind the 231 calipers if you have a flat an run the spare. So I got another 16" 5 star to replace my steel spare tire.
My experience with the 231 is it is a little more touchy than stock, with the abs kicking in on wet roads. It stops like a boss on dry roads.
Thank you all for the replies. I just ordered the stuff to do this, so I could be tackling this over next weekend. I guess I’m looking at picking up a 5star wheel down the road at some point.
Thanks again!
