Tundra/LC Lift Checklist - Before I Order Everything..
The shocks op has aren't fj80 specific. There tundra 5100s that the op has purchased. I was told to use rear fj80 shocks and during my research the fj cruiser 5100 has the similar specs to fj80 rear shocks. So I was asking about and showing an alternative.
If the FJ80 rear shocks will bolt up, then I don't see there being an issue. Actually, it MIGHT be better because they are a longer length, and have a longer extended length as well. So it could provide more stretch than my Tundra 5100's will.
I was mainly going off of these two threads:
http://www.toyota-4runner.org/3rd-gen-t4rs/101758-%2A%2Arickashays-ome-vs-trd-tundra-lc-review%2A%2A.html
and
http://www.toyota-4runner.org/3rd-gen-t4rs/154200-speedys-lift-install-how-video.html
And they both show the user using the Tundra 5100 Bilsteins, front and rear, with the front Tundra coils and the FJ80 coils in the rear.
Since I don't want to deal with the hassle of changing my order #'s around, I will stick with these rear shocks for now. If I blow them out, then I will look at the FJ Cruiser alternative.
Those are the threads ive also looked into. After purchasing LC coils from a member here, he mentioned using fj80 shocks, when I was planning tundra shocks. Since I work at an automotive shop I starting pricing shocks and got into comparing specs and found the alternative.
Would you recommend going with this shock:
Bilstein 33-187174
Over the Tundra Bilstein: BIL-24100144 ?
I have already placed the order, but it hasn't shipped out yet so there's a possibility I could change it. Please let me know asap! I will be running LC 8-wraps in the rear.
Depends on what kinda ride you want. With bilstein 33-187174 which fit fj cruiser , 03+ 4runner and 01-07 sequoia. On a 3rd gen 4runner, it is recommended to use toytec superflex coils. Which are tall coils. Taller then OME coils. And this reason is so you don't blow out the shock with small coils by over compressing the shock. Next you'll neen extended bump stops. Basically this brings the down travel back to normal, but you get a lot of up travel with bilstein 33-187174 vs the tundra. So it's something to thing about.
And in theory, I believe any first gen fj cruiser rear shock should bolt to our 4runner. So basically any rear fox, or icon for fj cruisers should bolt up.
But in my application, with my LC 8-wraps, which shock would be smarter for me to use?
Not exactly sure how much the 8 wraps give you lift. But I believe you are better of with the 5100 fj cruiser. I think but not 100% sure, that the 8 wraps give more lift then superflex. Don't forget, keep in mind about weight, and armor. I believe the LC coils aren't really good with weight. And I think you need the front LC coils to put it on the back of our 3rd gen.
8-wraps give about 4" of lift I believe..hoping that once they settle it will be less. They are the LC coils off of the FRONT of a FJ80, you are correct. But the shocks would still be the rear shocks, correct?
The shocks that will work are FJ CRUISER FIRST GEN RESR SHOCK. Which is fj cruiser 07-09. And part number is 33-187174 aka long travel shocks , that's what toytec calls them under the 3rd gen. So I'd get those with the 8wraps.
If you want to use FJ80 shocks, yes that is correct. FJ80 front shocks have pin/pin on the ends for attachment. Rears are pin/eye like the 4Runner.
You don't need the panhard drop. You don't need those isolators either if you bought new top hats. Also the tundra rear socks are correct. You'll need lower bushings.
Running any Armor up front? If not you may want to go with the first perch. Second for me was really high.
What height lift does the first perch give you?
Also what is the deal with the rear bilstein .75 bushing replacement on brand new bilsteins? Why?? why do they have to be changed? is it bc we are putting tundra bilsteins on a 4runner and the mounts are different? if so, how exactly is the best way to change the bushings?
I just put FJ80 rear shocks on my truck. They are Pin/Eye, they need no modification to work on our trucks.
fj80 springs on 4runner
red october, how do those fj80 springs feel on the 3rd gen? How much lift do they give you? I am looking for a softer feel?
You mentioned that with these the bushings do not have to be changed, does that mean they do have to be changed if I put the Old man emu 906 springs on my 3rd gen?
Thanks,
Mike
Thanks,
Mike
Im just running the rear FJ80 shocks, factory Tokikos, ($42, from camelback toyota). They bolted right up, no mods.
Im running them with OME 891 springs. They are right at 3" taller. But I dont really have any seat time with them so I cant comment about how they ride yet. Im hoping for a little more truck like ride, slightly less mushy than stock. And able to handle a little more weight than the LC springs seem to. I went with LC shocks because the OMEs seem to be too stiff for many folks.
Sorry top highjack the thread but got a quick question
Planning on buying Bilstein 33-187174 for my 9 wraps, I currently have the Rancho shocks but the boot is torn and I dont know if the previous owner bought them used or how long its been on for.
Will these bolt on right to rear 4Runner? How will this ride? Still have my sway bars connected since im all highway driving but I take them off when I go off-roading. any opinions?
Hey guys so i have been looking at the fj80 rear structs and toyota tundra struts for the front. I'm new to all of this and not sure if I have it all correct. Can someone take a look at the links and see if im good with buying these?
Toyota Tundra 2000-2006 Brand New Direct Fit PAIR of Front Struts With Springs
Toyota Tundra 2000 2006 Brand New Direct Fit Pair of Front Struts with Springs | eBay
2 Rear 50mm Lift Coil Spring Landcruiser 80 Series FJ80 FZJ80 HDJ80 HZJ80 1991-98 Toyota Wagon Pair
Pair Rear HD 50mm Lift Coil Springs Landcruiser FJ80 FZJ80 HDJ80 HZJ80 1991 1998 | eBay
Rear Gas Shock Absorbers Toyota Landcruiser FJ80 FZJ80
Rear Gas Shock Absorbers Toyota Landcruiser FJ80 FZJ80 | eBay
NO NO NO!
1st. Tundra front struts must be from the TRD model and have a certain color code on the coils to work. Those aftermarket crap coils will ride like junk and may net zero lift.. You want to go with used or new OEM Toyota Tundra coils with correct color combo.
2nd. You dont want Land Cruiser rear coils to lift your rear end. You need the FJ front coils to lift our rear. Also you dont want heavy duty after market coils since they might give you way to much lift.
3rd. Every thing you need is here. http://www.toyota-4runner.org/3rd-gen-t4rs/101758-**rickashays-ome-vs-trd-tundra-lc-review**.html
Dude..how many times are you going to post the same stupid question? The answer you need is in literally every thread you've posted in. LITERALLY every part # and even where to purchase the parts is also in all the threads you posted in. Stop being ignorant and search/read instead of posting in multiple old threads.
2001ATL
