Turn Signal Not Illuminating With Parking Lights
paczowski123
So my turn signals have never illuminated when I have my parking lights or DRL on in my 2020 TRD ORP and I always thought that’s how it was designed until I passed another 4R today and their turn signals were illuminated. The previous owner looks to have installed LEDs in the turn signals, could that be the reason, or is it some sort of setting? Pic attached showing parking light not illuminated.
Upon further inspection I attached a photo of the bulb in the socket, it has a pigtail connector on it and I CANNOT figure out how to remove it. It almost feels like it just presses into the socket because when I spin it, it spins a full 360 degrees, anyone have an idea of how to remove it?
They aren’t on with DRLs. Not sure about parking lights as I haven’t paid much attention. Are they ever on?
If they used 7440 instead of 7443/7444 then that could be the issue. Pull the LED base out of the truck side plug. If there’s 2 pins/legs, it’s the wrong bulb type.
Thanks, they don’t illuminate with headlight either, and they’re supposed to right? Parking lights are one turn past DRL where tail lamps and corner/turn signals illuminate.
My issue I’m having now is I CANNOT get the bulb out. It just spins, so I think it’s one of those cheap universal bulbs with just the rubber grommet on it holding it in place and I’m worried about damaging the headlight, plus there is so little room to work in there.
If I can get them out I’ll just go back to the amber OEM style.
Try rocking them from side to side, not just rotating them or pulling them back.
Thanks! Yes not that I realize they’re just pressed in I’ll try and get them out when I have a chance. I was just worried if breaking them or the bulb falling inside the housing.
Right. I got that you can’t get the bulbs out. I was talking about the base that goes into the truck harness. The gray plug that the LED is connected to. If you pull that out and it on out has 2 legs/pins/whatever you want to call them, it isn’t the right type of light
I’ll check it out today, I’ll be replacing whatever junk is in there with OEM amber type bulbs for ease of maintenance and hopefully have running lights as designed up front again. If I ever get the urge to have LED running lights and turn signals I’ll be installing something that plugs into the socket itself.
Well here is the final product of removing that cheap junk the PO installed on my 4R. Had to basically destroy the bulbs to get them out using pliers. I am glad it didn’t damage the headlight housing. For someone to spend that much on a vehicle like this then skimp and put this crap on it blows my mind.
If you’re ever thinking of using universal bulbs with the rubber grommet, DONT! They’re a PITA to remove especially in tight places.
Glad you got them out! The 2 wires means they were just turn signals. The turn signal and marker light would have 3 wires. Did you get 7443 or 7444? I couldn’t find any 7443 when I replaced mine
I got 7444, which is what the manual called for.
Ambrose67
