Uneven serpentine belt wear
rfuree11
I everyone, I've been lurking here for a while and haven't needed to post. I bought my 4Runner about a year ago and have come across a weird issue that I figured you could help with.
I changed my oil the other day and noticed the serpentine belt was pretty worn, so I replaced it. Today, I looked under the hood and noticed that the new belt was worn pretty much the exact same way. This belt has less than 100 miles on it, which is a little disconcerting. One rib is worn pretty significantly. This is on an 07 V6 with 65k miles on it. I bought it CPO last year and am assuming the old belt was the one from the factory. Thanks again for your help!
Here's the new belt:
And here's the old one that I fished out of the trash:
check all your pully's for play and debree, check to see if anything is rubbing the belt that shouldnt be if all that checks out you may have bought a bad belt and not noticed at first but I doubt that lol.
The two of you nailed it. I was trying to avoid going outside because of the rain we're getting now. I braved it and pulled the belt. Once I pulled it and spun the AC compressor pulley, there was a decent sized pebble wedged into the groove :ybrick: . Now I'm off to find a gatorback, since the one in there was a cheapie. Thanks for the help.
RC_Fabrication
