Uneven wear on passenger side tire
pelle047
I have a 2.5 inch spacer leveling kit on my 2wd v8. I also have fj springs. I put on the spider trax spacers with my old 255x75x17 and there was no issue. The moment I put on my 285s my truck has a vibration and doesn't ride right. I also noticed that the front passenger tire is wearing on the outside but not the inside. The alignment was redone right after I mounted them. A local shop told me that I'm "skipping tread" and it's a suspension issue.
1. Is this true?
2. Is it easy to fix?
3. Would it be easier to just down size my tires again?
how many miles on it? bad shocks can cause that type of wear.
usually its due to not rotating the tires often enough, but generally affects each side equally.
